Sunroof stuck
Old Sep 10, 2011 | 05:02 PM
cdy_626's Avatar
Sunroof stuck
Hey everyone
So I was driving to day and I tried opening my sunroof and it wouldn't open. It flips up, but it doesn't ope. I know it's not the mechanism because it was trying to open but it just seems to be stuck. I flipped it up so I can look to see if there was anything stuck around the tracking but didn't see anything. Anyone have any suggestions of anywhere else anything could be stuck? I opened the sunroof all the way when I drove it last night. And it was open while I was driving on the freeway. So I guess anything is possible. But today it doesn't open, it just the flip up that's working and it tries to open when I'm pressing the button.
Old Oct 12, 2011 | 05:49 PM
97greenclbro's Avatar
same thing happened to mine. all i did was try to open it at the same time having someone else pull up (or push up) on the roof. it opened then and since then i havent had a problem. you mightve tried this already but if not, go for it
Old Dec 5, 2011 | 04:26 PM
MikeSwing's Avatar
Same thing is happening to mine. It will crack up but it will not go down enough to slide into the roof. Anyone have a definite fix?
Old Dec 5, 2011 | 08:17 PM
saiko_cl_duck's Avatar
do you have the moonroof wrench? If you can open it manually, you should look at the relay or possibly the switch.
Also, you need to take a good look at something being jammed in the track, it doesn't take much at all to stick in the track.
You could remove the glass, I have the instructions if you want them. I would suggest a helper with that though.
Old Dec 6, 2011 | 10:19 PM
MikeSwing's Avatar
Where's the wrench?
Old Dec 6, 2011 | 10:27 PM
it comes with your owners manual. You can always take off the plug and find a suitable bit to put in there.
The cover plug is on the headliner towards the rear glass.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
eastcoastguy
Sep 23, 2015 06:29 AM
