Strange Idle problem when slowing down....
Old Aug 15, 2007 | 12:12 PM
ajbent86's Avatar
Exclamation Strange Idle problem when slowing down....
My car started to do this in the past few weeks. It never acually stalls, but apprears to get very close to stalling..........the RPMS drop to like 250 then she recovers and idles fine. It only happens when slowing down after i push the clutch in.
anyone know whats up with it?
Old Aug 15, 2007 | 12:18 PM
spencer_homer's Avatar
i like acura
theres a recall on the ignition switch. im pretty sure thats what is causing it, most peoples cars die when that happends
Old Aug 15, 2007 | 12:19 PM
F23CL757's Avatar
Fo' SHizzle
Ignition Switch Recall FTW
Old Aug 15, 2007 | 12:27 PM
ajbent86's Avatar
nope, that was done 2 years ago
Old Aug 15, 2007 | 01:04 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
maybe you need to ajust your idle up, i had to do that.
Old Aug 15, 2007 | 01:35 PM
ajbent86's Avatar
after it recovers from this "drop" it idles fine at around 1k rpm
Old Aug 15, 2007 | 02:29 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Clean your IACV, change your cap & rotor and it should fix your problem. The clogged IACV causes low idling and the old distributor rotor causes high idling. Your car could also use a tune-up....
Oh, the correct idle RPM range according to the repair manual is 700-800rpm.
Old Aug 15, 2007 | 03:24 PM
AznX TL's Avatar
where is....
i think under the hood tells you what your idle is suppose to be and how to adjust it, but i recommend a seafoam job.
Old Aug 15, 2007 | 08:10 PM
SupraManAG's Avatar
One custom CL
welcome to my world. i honestly believe it bad carbon buildup. ports get clogged and ECU cant balance your idle thru the vacuum which are restricted. then again thats what im stuck on because I have an all racing ignition and plenty on fuel pushed by the walbro.
Old Aug 15, 2007 | 08:12 PM
AznX TL's Avatar
where is....
when mine does this, i take apart the distributor and find that my igniter wire is loose and i have to tighten it back to the spot.
Old Aug 28, 2007 | 10:10 AM
Dan3952's Avatar
I used to have this happen, rpm's drop to 400 or below and back up before it stalls. Like is talked about in the other post, probably the dirty IAC valve will make rpm's drop momentarily. I did a Seafoam job and it never happened again.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Robospinner
22
Sep 24, 2015 08:47 AM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
