starting problems
starting problems
K im sorry i know its probably been covered before but idk wht search term to look under and anything i put about starting went back to starter battery or alternator dieing out and none can be my problem becuase after i unplugged the car battery for 5 min and plugged it back in it started up fine and i was on my merry way.
So here is the problem i turn on my car engine cranks over starts up normal after 2-3 secs after the initial rpm increase the engine shuts down so i try again now hitting the gas as long as i have the gas going car stays on rite after i take it off it dies again. What could the problem have been my initial thoughts was fuel pump or filter but i had a new filter put in last summer and then idk bout pump because it started working just fine after i had the battery off for a minute.
Any ideas what the problem could be or possibly just sum shitty luck for like 5 min of time.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Idle control valve or alternator
sorry it is a acura cl 3.0 and its not alternator got it checked today and mechanic said nope i think i checked the iacv thats the little flipping piece as rpms go up right? how would that mess up the car wouldnt that just give me shitier gas mileage.
it only did it that one day and never happened again so idk wtf it could be idle is fine doesnt change at all since i did that seafoam back in last summer and cleaned out the egr valve. Sumtimes the engine runs soo smooth i fuck up my starter cause i try to crank my car while its actually running. So i doubt its anything with engine problem
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
