Srs Light Fix !!!
Old Sep 20, 2005 | 07:43 PM
ayougo's Avatar
B A N N E D
Srs Light Fix !!!
After some research i found a solution here it is
Make sure the ignition switch is OFF.
MES Connector
1 Connect the SCS service connector (A) to the MES connector (2 pin) (B). Do not use a jumper wire.
2 Turn the ignition switch ON).
3 The SRS indicator light will come on for about six seconds, and then go off.
4 Remove the SCS service connector from the MES connector (2 pin) within four seconds after the light goes off.
5 The SRS indicator light will come on again. Reconnect the SCS service connector to the MES connector (2 pin) within four seconds after the light comes on.
6 When the SRS indicator light goes off, remove the SCS service connector from the MES connector (2 pin) within four seconds .
7 The SRS indicator light will blink two times indicating that the memory has been erased.
8 Turn the ignition switch OFF, and wait for ten seconds.
Old Sep 20, 2005 | 07:51 PM
ayougo's Avatar
B A N N E D
this part cost 3.51 at h and A http://www.handa-accessories.com/odymaint01.html
Old Sep 22, 2005 | 06:42 AM
RedX's Avatar
97 Acura 2.2CL 160k miles
My SRS light is always on, one day it decided to just stay on full time. Will this work for my problem?
Old Sep 22, 2005 | 09:02 PM
ayougo's Avatar
B A N N E D
yes
spidermankb
Mar 5, 2019 11:34 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
JnC
Sep 11, 2015 06:06 AM
MikeYutkin
Sep 10, 2015 10:13 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
