speedometer and odometer issue
Old May 6, 2015 | 03:57 AM
bxsoccerplayer's Avatar
hi I was just asking for some help trying to fix my speedometer and odometer.i cant see how fast im going plus how far im going. its stuck at 166,168 miles btw its a 1997 Acura CL TIA.
Old May 6, 2015 | 08:28 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Moved to 1G CL.
Old May 9, 2015 | 04:36 PM
Showmeyourtints's Avatar
You may have a bad VSS or it may be unplugged. It's on top of the transmission, passenger side of the vehicle. It has a plug and wire attached to it and is mounted on the trans with a single 10mm bolt. Does the vehicle rev past 3k rpms and are you hitting vtec?
Old May 9, 2015 | 07:56 PM
Yes it does pass 3k and I'm not really a mechanic I just getting advice to show a friend so he know what to do so idk what you mean by vtech
Old May 14, 2015 | 12:18 AM
musiclevelz5's Avatar
Also on some of the trans the vss is removed and the countershaft speed sensor is used to determine vehicle speed. Since your speedometer stays at 0 then the odometer does not read any mileage increase either.
I believe in either case you need to replace the vss/ cs speed sensor. This will fix both issues simultaneously.
If you gave more info about your car I could see which sensor you have. Whats your engine and trans type?
Old May 22, 2015 | 04:12 PM
anupjthomas's Avatar
If you had a scan tool, you could see if your ECU is reading speed. If it is, your problem could just be your dash.
My dash is very finicky. When I turn the headlights on, I have to slap the top of the dash just the right way to get the lights that illuminate the pointers to go on. When I have the time, I'm taking the dash out and have me a soldering party.
Old May 22, 2015 | 11:37 PM
You need to buy new bulb bases. I had the same issue in my CL. new bases fixed it. Very cheap too.
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
1G CL Tires, Wheels, & Suspension
Oct 18, 2015 07:48 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:38 PM
Sep 17, 2015 08:57 PM
vbgregg
Sep 11, 2015 05:38 PM
