Short Ram and ABS
Old Mar 8, 2011 | 11:46 AM
catalyst529's Avatar
Question Short Ram and ABS
After installing SRI the ABS came on. All brakes are engaged could brake booster be the cause?
Old Mar 8, 2011 | 07:23 PM
Acura1997Cl's Avatar
my abs light is always on car still runs and drives fine you just control the stopping instead of a cpu (I prefer it that way) but if a really bothers you a >10min scan can tell you exactly why it was on but i would bank on a loose wire or something wrong with sensor, or a few fuses that you can check.
Old Mar 9, 2011 | 01:52 AM
I've checked the ABS fuses are there any others
Old Mar 9, 2011 | 08:34 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Most likely it's a wheel speed sensor, I've replaced 3 of mine, and still need to replace another one
Old Mar 15, 2011 | 01:14 AM
end up finding out what was wrong. there was a 10 amp fuse in a 7.5 amp slot. i changed it out and the abs light turned off and the brakes released.
Jamus22
Jun 11, 2023 10:08 AM
Jul 16, 2017 07:33 AM
ceb
ILX
Sep 27, 2015 10:56 AM
AcuraKidd
Sep 25, 2015 11:18 PM
