shift lock release
Old Dec 17, 2006 | 07:10 PM
floppsb's Avatar
3rd Gear
Unhappy shift lock release
I've spent about the last hour looking through the posts here, trying to find someone that had the same problem as I have had. My black 97 3.0 has about 68k miles on her, and two days ago I couldn't pull it out of park, at least without using the shiftlock release. Now I'm assuming this means my transmission is starting to go bad. I haven't had any problems with jerky shifting, and I've gone through 2 transmissions on other vehicles, so I know what to expect when transmission problems are on horizon. On a "normal" acceleration, I find that it shifts between 2 and 2.5k rpms, so I am having a hard time believing that the tranny is about to die. Anything else it could be?
Old Dec 17, 2006 | 07:23 PM
AznX TL's Avatar
where is....
its the brake release thing......i forget what its exactly called
Old Dec 17, 2006 | 10:53 PM
CLean 3.0's Avatar
CLeanest in its CLass
try testing the brake switch i just had to replace mine on my 97 it wouldnt let me shift out of park especially after sitting over night.
Old Dec 18, 2006 | 12:50 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like your brake switch is broken or stuck, check it first, it's the switch behind the brake pedal
Old Dec 18, 2006 | 08:51 AM
TexasHonda's Avatar
Have someone stand behind car and confirm whether brake lights are coming on when you press the brakes. If not, you know the brake switch is not closing. I had this issue on my 2.5TL recently and was able to fix by simply spraying the brake light switch liberally w/ WD40. That's been several months ago and problem has not returned. I don't know about CL, but on the TL the brake switch is practically inaccessible w/o disassembly dash partially.
good luck
Old Oct 17, 2009 | 05:48 PM
MUCKBOY83's Avatar
Did you figure out what the problem was?
Old Oct 17, 2009 | 06:03 PM
Ron A's Avatar
Administrator
Welcome to the forums.
This is a 3 year old thread and the original poster is long gone, so you probably won't get a reply from him.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
