Right side power door lock not working
Old Apr 10, 2011 | 12:47 PM
merrym100's Avatar
3rd Gear
I have a 1997 Acura 2.2CL with a little over 100,000 miles on it. I just replaced the left side door regulator and it works good. Now my next project is fixing the right side door. When I hit the remote or lock button, the right door doesn't lock or unlock. I have to door pannel off and the rod doesnt move either. Any ideas??
Old Apr 10, 2011 | 01:00 PM
replace the door lock actuator
Old Apr 10, 2011 | 04:34 PM
TAco23's Avatar
is it possible to rebuild door actuators? just a thought. How much do new ones run these days??
Old Apr 11, 2011 | 06:48 PM
merrym100's Avatar
3rd Gear
Okay I will check into that. Any ideas if that could cause the alarm to randomly go off? It used to do it periodically then quit. Now that I took the right side door panel off, it is doing it again.
Old Apr 11, 2011 | 06:51 PM
^so your left door wasnt working, and you replaced that. Now your right door isnt working....and the alarm is going off?
sounds like an electrical problem.
bad battery?
Old Apr 11, 2011 | 06:57 PM
merrym100's Avatar
3rd Gear
No I replaced the window regulator and motor on the left (drivers) side. Put that all back together and took the right (passenger) side apart because for a few years now the power lock has not worked on that side. Right around when it quit working the alarm would randomly go off and then quit. Now that I took the door panel off it's doing it again. Would this have a relation with the door actuator that is bad?
Old Apr 11, 2011 | 07:00 PM
Dont have a CL, but just going off of logic here.
if the door doesnt lock/unlock its the door lock actuator.
Dont know if this has anything to do with the alarm going off.
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
