Problem with polishing headlights..
Old Nov 16, 2010 | 02:34 PM
KongZTT MD (2.2 CL)'s Avatar
8th Gear
Hello,
I am new to Acurazine.. I just purchased a 97 2.2CL, 5spd as my daily driver a few days ago..
So far I love it!
I did the blackhouse to my headlights and ordered some HIDs..
I decided it would be a great time to polish up the foggy headlight housing lenses.
Now, I am familiar with polishing headlights to get them to look brand new.. However; I am having a problem with my passenger side headlight.
It has a film in certain areas that I cannot take off.
I wetsanded/soapy water from 800grit, 1000grit, 2000 grit, then mothers aluminum polish. I just cannot seem to remove the film..
I can feel the difference in surface texture where the film is.. It did not come off when wetsanding.
Is there something I am doing wrong with these acura headlights? or are these just too far gone for any reconditioning?
I have not tried the 3m plastic polish yet though.. I figured the mothers aluminum polish should've done good enough.
Has anyone else had this issue and got it resolved? I can post pictures of necessary.
Thanks in advance!
Shawn
Old Nov 16, 2010 | 04:04 PM
P0401's Avatar
I have polished mine twice so far and have never had this problem. I am not sure what the film is that is on your headlight but you may need to get a coarser grit sand paper to get it off and then go with the finer grit to finish polishing it out
Old Nov 16, 2010 | 04:33 PM
8th Gear
It is an odd film.. its mainly around areas where the light would pass through when having lights on..
I went as low as 800grit but wetsanded with a good amount of dawn dish soap.. maybe it was a little too slippery..
I did however wetsand with 800 grit for a good 15 mins across each headlight, using swirls, back n forth etc..
I'll go down to like 600grit and step its way up ..
thanks for the reply!
Shawn
ps. Do you know of a good mounting kit for using an aftermarket single din headunit? Or a good way to mount the stock storage housing with it?
I kind of like having the door on it, makes it look classier..
I have heard there was two different types that are sold at bestbuy and one was good, the other sucks..
a possible picture of the "good" one?
Thanks again..
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
rboller
Sep 23, 2015 02:49 PM
