power steering???
power steering???
When I turn on my car, it sounds like a dying caprice classic from the 80s. I can hear it most when I idle. Took it to a shop today, he told me it was my alternator. A couple other shop guys told me it was the o-rings on my power steering pump. I thought there should be some indication that there was air getting into the pump if the o-rings are shot, so I looked, and everything seems fine. I don't know what the heck is wrong but it sounds so horrible...getting embarrassed to drive it...what do you think the problem is???
If fluid level is OK, check for a small leak in the suction hose from reservoir to pump. This may allow air to be pulled in when pump is running. A dirty, partially blocked filter in bottom of the reservoir might enhance this affect.
good luck
good luck
Acura604
20
08-05-2017 12:55 AM
