Noisy AC compressor, But AC is still strong…
Hey guys… My AC is squeaky and sounds horrible when it kicks on but the AC is strong and working great. Is it possible it’s just the clutch / bearing mechanism? How would I tell? How hard is it to replace, and can it be done without effecting the un-pressurizing the system.
Any insight would be great!
damn same problem with me good a/c but noisy ass hell compressor especially when i shift gears its when i hear the most i`ve tried one of those cans of freon that say that lowers the noise of compressors but didnt work for notten
If you shut the car off, remove the drive belt, and rotate the compressor pulley(outwe part) by hand, you should be able to feel and hear the clutch bearings grinding. The pulley may actually wobble a bit indicating excessive bearing play.
In-place repair w/o discharging system requires remove PS pump and alternator first. Then remove the AC compressor mounting bolts and tilt the compressor to access the compressor clutch assy. Remove clutch plate (don't loose thin shim washers under the plate), remove snap ring w/ snap ring pliers (this is tricky because access is not great,...patience). Tap rear outer edge of pulley w/ a hammer to remove from compressor. It may come away just by pulling w/ fingers. A new or used clutch assy is installed in reverse operation.
Suggest downloading the 94-97 Honda Accord shop manual from hondahookup.com. Your compressor design details are the same. The AC section is perfect your your application.
good luck
good luck
good luck
good luck
also found this:
http://www.autopartsauthority.com/pa...1&make_code=AC
but I think that comes with the electrical componets also which I don't need...
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
