Need to correct headlight orientation (noob request)
Old Apr 3, 2007 | 06:41 PM
justforkix's Avatar
5th Gear
The headlights on my CL seem to be pointing way too down for my liking. Can someone tell me how I can change the orientation?
Thanks!
Old Apr 3, 2007 | 06:51 PM
Dicorp's Avatar
dig out your users manual, theres a section on how to aim ur headlights
Old Apr 3, 2007 | 07:17 PM
herbalist's Avatar
chips and smokes, lets go
there should be a small dial on the back of the headlight that turns which adjusts where the beam shines. that being said, i turn and turn my dial and nothing happens.
Old Apr 3, 2007 | 09:14 PM
AznX TL's Avatar
where is....
i would also like to know this, because my headlights shine straight down.
Old Apr 11, 2007 | 09:51 PM
I Fear No Five O's Avatar
This how I adjusted my headlights:
1. Pop the hood and look at the headlight assembly on each side.
2. Directly above each headlight assembly, there should be a metal frame/panel type of thing with only two bolts in it. The bolts are about 6-8 inches apart with a small level indicator (one of those bubble things) in between.
NOTE: If you have a 3.0, there is a plastic cover that shields the area above the headlights. Just remove that plastic cover and continue.
3. Take a 10mm socket and loosen the two bolts but DO NOT take them out. Your headlight assembly should now be able to move up and down freely.
4. Adjust the headlight to where you want it and while holding the headlight at the desired level, tighten the bolts down.
5. Do the same with the other headlight assembly.
6. If you have a 3.0, put the plastic cover back on when you're done making adjustments.
I hope this helps and good luck.
Old Apr 11, 2007 | 09:58 PM
I'm pretty sure the dial behind the headlight allows you to adjust the beam from side to side, not up and down. I haven't messed with that but from what I hear, it takes A LOT of turning before you notice any changes.
Old Apr 11, 2007 | 10:05 PM
herbalist's Avatar
ya like i said, turning mine does nothing. theres a good chance i messed something up when i was blackhousing the headlights. i also tried adjusting them like you mentioned in your earlier post. that was the first thing i tried. its still not where i want it to be though.
Old Apr 15, 2007 | 12:20 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
Talking
If any one listen to this guy you are a retard
Old Apr 15, 2007 | 01:44 PM
saiko_cl_duck's Avatar
okkkaayyy..............
Old Apr 15, 2007 | 01:58 PM
Mach30SiR's Avatar
Bagel Bomber
i thought there were just some screws you had to turn. i could be wrong again, but the listed instructions above seems a little hard.
Old Apr 15, 2007 | 02:09 PM
abouelmm's Avatar
kl-de
he is right, there is a dial you have to turn with a 10mm, when i got my hids i was like depressed cuz they were bright and all but they aimed straight to the ground then i figured out how to adjut the headlight, do it in the dark or fairly dark and agianst the wall so you see if they are both even or not
Old Apr 15, 2007 | 02:28 PM
I got a 2.2 so i may be wrong but on mine they're are dials on each headlight and you basically need to do it at night against a wall and adjust em with a screw driver.
Smart ass
Old Apr 15, 2007 | 02:36 PM
ZeroCL's Avatar
W WHIP.
smarty smart pants...
i need to adjust my headlights soon. They're like crosseyed. haha
Old Apr 16, 2007 | 08:29 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
All you have to do is adjust the dials with a phillips screw driver, you would have found that info if you searched
Old Apr 16, 2007 | 08:25 PM
Hey I'm just repeating what a guy at the local Acura dealership told me to do. And it worked well for me, so now my headlights aren't pointing straight down anymore.
hashbrown
Feb 18, 2022 11:20 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
Mr.Tea
Oct 2, 2015 10:32 PM
