My Car Is Using To Much Gas
Old Feb 23, 2008 | 11:21 PM
Hondaclub69's Avatar
Vtec For You To Envy
hey my car is getting 13. miles to the gallon which is horrible and 18 on the high ways i live around boston, could it be my PCV valve is not working correctly everything else is working and i use good gas can anyone help me?
Old Feb 23, 2008 | 11:26 PM
asianspec's Avatar
tune-up, clean egr valve, check tire pressure, seafoam.
Old Feb 24, 2008 | 12:12 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Plus plugs, wires, and new cap. Sounds like the car is running too rich
Old Feb 24, 2008 | 01:56 AM
DaInFaMMuS1's Avatar
u live in BOSTON..nuff said lol
but on the real check the caps plugs and wires and also for miniscule exhaust leaks and whatnot...ur car will be fine.
Old Feb 24, 2008 | 02:21 AM
AznX TL's Avatar
where is....
could also be from the fuel is winter mix, plus having the heat on all the time doesnt help either.
Old Feb 24, 2008 | 06:38 AM
thanks guys but look ill show you some figures My car Is using way to much gas at idle its about 7.2% to 10% short fuel trim long is about 1.7 i replaced the air filter the fuel filter and spark plugs going to do roder and cap and wires my egr valve is clean look inside of it i got acura cl 3.0 1997 theres no vacum leaks i put a smoke machine tester to it umm what else the picoscope graph on zirconium it looks ugly goes up like a hill then its spiky shoots down a little then spikes back up feels like a missfire but no codes come up umm i too the air screw out of the manifold clean back there it was a little carbonated. the car is staying rich switching sometime to lean the o2 sensers are work im thinking the car is thinking that its cold still when its really warm and it keep inriching it but i dont know what else to do has anyone had this probblem its winter in mass i was getting 16 17 miles per gallon now im getting 13 can anyone help me im going to try a engine cleaner and i did throw techstron in it to clean the injectors still not working
Old Feb 24, 2008 | 10:05 AM
spiderman3098's Avatar
sorry dont know too much of everything you said, but when i was getting that shitty gas mileage i went for the entire package.
I cleaned out the egr valve was like half clogged, changed spark plugs wires and cap,and both air and fuel filters, checked my tires and alignment(did you know shitty alignment can also kill some your gas mileage...actually idk i just took it at face value may or may not be true).
O b4 you do all that with your old sparkplugs still in run seafoam through ur engine twice, Or basically throw one full can through the vacume hoses use both pcv valve and brake booster lines.
Then use another half can in ur gas and half in your oil. Drive around like that for one tank or less than 200 miles and get a oil change and replace your sparkplugs and reset the ecu.
Doing all that made my avg gas mileage go from 17-18 to averaging 22-23. Hope This helps o the only reason i say 1 full can is because most ppl dont do seafoam every 20,000 miles like the can says so theres always more build up then one "servings" worth.
Old Feb 24, 2008 | 04:11 PM
saiko_cl_duck's Avatar
Please man, use punctuation. People are more apt to help if they can read what you wrote.
Old Feb 25, 2008 | 05:39 AM
Sorry...
Old Feb 25, 2008 | 07:25 PM
FRFM00's Avatar
CLs have a mind of their own.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
kuzdu
Sep 10, 2015 08:42 PM
BlueAquarian
Sep 10, 2015 02:18 PM
NSolace
Sep 3, 2015 08:14 PM
