how to read 97 cl abs code
Old Jul 4, 2009 | 01:04 PM
syain's Avatar
I search the forum and somebody said I can get the code by shortening the check connector under the glove box. But I don't know which one is the connector.
Can anybody give me some hints?
Old Jul 4, 2009 | 07:15 PM
TexasHonda's Avatar
It's a two wire connector, usually blue, and may be plugged into a plastic dummy connector that is attached to underside of dash. Look under glove box area.
When you short the service check connector, turn keyswitch to ON, the ABS light will flash codes, all short flashes w/ short pause between 1st and 2nd digits. Code 41 = ffff-p-f. There will be a 2-3 sec pause between separate codes or repeats of same code.
good luck
Old Jul 30, 2009 | 01:01 PM
syain's Avatar
I got the code 4-8.
Where can I find the meanings of this code?
Old Jul 30, 2009 | 04:52 PM
syain's Avatar
I searched online and it says 4-8 means left rear sensor problem.
Somebody says that cleaning the sensor will help, most of the time cleaning will fix this problem.
Is that true?
Do I need to pull out of the wheel to remove the sensor?
Thanks,
Old Jul 30, 2009 | 05:23 PM
Tehvine's Avatar
6spd FTW
Taking off the wheel would certainly make your job a whole lot easier.
Old Jul 30, 2009 | 05:37 PM
syain's Avatar
Can I use the back trunk tools to remove the wheel? I don't have any jack stands.
Old Aug 1, 2009 | 09:47 AM
syain's Avatar
I clean the censor, but id does not work. The abs light still on....
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
