how to open air filter housing? Please help!
98 CL 2.3. The owner manual says unscrew all the four screws. However, I'v tried all kinds of pillips screw drivers availabe at home, not working. it seesm the screws are locked.
Please help!!! Thank you.
Originally Posted by saiko_cl_duck
wrong sub-forum, moved.
Try turning harder
I've never had a problem loosening those screws before when I had the stock box. Try some WD-40 to break up some corrosion. Do the look stripped out?
Try turning harder
By locked, I mean the screws are mechanically locked because they can be easily turned a little bit, clockwise and counterclockwise. Do I need to use a nut driver?
Sep 17, 2015 09:01 PM
