Horn sounds when I turn off headlights
I've got a pretty significant problem that just started occuring on my 97 2.2 CL.
Last night when I was driving home, I saw a little bit of smoke and a slight burning smell... I noticed my gauge cluster lights getting dimmer. Then the left indicator on the dash just lit up and stayed on, and the left blinker itself wouldn't work anymore.
Finally, when I get home, I turn the car off and shut off the lights, and my horn starts blaring nonstop, until I turn the lights back on. So I had to pull the fuse, which disables my brakelights...
I'm guessing there was some sort of short or something because of the smoke. Anyone heard of this problem before? I gotta figure out how to fix it, and quick
Fast Foward>Rewind>Play
Sound like nothing you can do unless you can rewire electronics, Take it to the perfessionals if you want the job done right. Im guessing it did short.
ive heard of a wire connector in the steering wheel that rotates kind of like a goose neck on a bmx bike. i dont recall what its called. but im pretty sure thats where the problem is.. someone here has had the same problem before.
rockyboy
08-04-2024 10:35 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
