hmm wierd
Old Oct 28, 2006 | 10:28 PM
AznX TL's Avatar
where is....
hmm wierd
when its cold out, my speedmeter freezes and jumps from like 0 to 15 and then to the speed im traveling. and it sometimes will stay at the speed when im at a complete stop, but after a bit of warming up it goes back to normal.
need help! hopefully if i get caught speeding the speedmeter will still be stuck and i can try to get out of the ticket.
Old Oct 31, 2006 | 06:12 AM
TexasHonda's Avatar
The most likely reason is a faulty Vehicle Speed Sensor (VSS). The VSS plugs into the transmission and generates a pulsed voltage signal that is used by the instrument panel to drive the speedometer and odometer movements. They are prone to fail in all Hondas and Acuras. Check ebay for a low priced replacement part. OEM is pricey.
If you're really into DIY, you might remove the sensor, disassemble, clean, and regrease the rotating magnet and clean the sensor face. I recently opened one I removed from my 2.5TL and found the grease had gone very stiff and burnt. If you do this the amount of grease should be limited and placed under the rotating magnet, not on the magnet body. You don't want anything to interfere w/ magnet inducing voltage into the coil sensor.
VSS is behind the distributor on the transaxle. Remove inlet to access.
good luck
Old Oct 31, 2006 | 12:26 PM
97clpushit's Avatar
i can not find where the hell is it
Old Oct 31, 2006 | 04:33 PM
AznX TL's Avatar
where is....
hmm sounds like a pain in the ass, i think ill just wait until the car warms up instead of replacing it
Old Oct 31, 2006 | 07:14 PM
97clpushit's Avatar
i check autozone and they want like $49 but i can't find the vss on my car 2.2cl is it still on the transaxle behind the distributor
Old Oct 31, 2006 | 07:19 PM
AznX TL's Avatar
where is....
is yours a 5-speed or auto?
Old Oct 31, 2006 | 07:34 PM
97clpushit's Avatar
auto
Old Oct 31, 2006 | 07:56 PM
AznX TL's Avatar
where is....
i believe this is where its at
Old Oct 31, 2006 | 08:04 PM
97clpushit's Avatar
is that the transmission
Old Oct 31, 2006 | 09:23 PM
AznX TL's Avatar
where is....
yeah
Old Oct 31, 2006 | 09:52 PM
TexasHonda's Avatar
That is the entire drive assembly including the gear that engages the drive shaft. You only need to remove the VSS, which is electrical part connected to the top of the assy. There is a small link which engages a slot on lower drive unit to turn the VSS magnet.
I would highly recommend some type of shop manual. Even an Accord manual would help.
good luck
Old Oct 31, 2006 | 09:57 PM
AznX TL's Avatar
where is....
good luck
yeah, that was the best picture i could find of it, but thanks alot for your help
acuradan69
Wash & Wax
Aug 9, 2001 10:19 PM
