high bead problem.. not working at all??!?
hey all..
so yeah i've just had this car for about a month now and the highbeam never worked.. i put new bulbs in... i have a realy bad memorie but i think they didnt work at first when i put them in and then after a while it worked.. then in a couple days 1 highbeam light went out... and after a couple days later i think they both stoped working... so does anybody here have a clue whats wrong? maybe a fuse?
Originally Posted by johnnyblaz3
hey all..
yeah try checking the fuse..........
ok ill try that... one weird thing that happend today while i was driving in daylight Without any lights on at all... sooo the DRL light was on like usual and the highbeam light was also on for some reason(the DRL and HB are always on) higbeam wasnt actualy on but it showed up..... kk so the weird thing is that the DRL and the HIGHBEAM light were blinking for a bit and then stoped!?!? whats going on here ppl is my car haunted or what
oh and and while i drive with my lights on for nighttime driving the HIGHbeam light goes off... but daytime is usualy on dont know why... DRL light is always on... is it supsed to be??? also srs light on and abs lights are on
kk i checked the wires and they seem to be fine.... i checked the fuse but it doesnt say highbeam anywhere and the fuse box under the hood is french so i cant read most of it... could somebody help me on this??.... is the highbeam fuse under the hood or is it in the car under the drivers spot?
the reason your high beams dont work and your DRL light is on is because your DRL relay is faulty, some places will fix it for you for cheap and other will insist that you buy a new one,. 150$ or more...
I had this for two and a half years.. there's a circuit board under the dash, behind your steering wheel. One of your relays is probably loose and its feet need to be resoldered.
There's a DIY archive for this somewhere on Acurazine that I went from..
the same exact overheating is happening to me, but when mine goes up to high and i acclerate, i hear a whinning noise, as im driving, the temp drops back down to normal and the whinning goes away. i bought prestone anitfreeze collant and prestone raditior flush. gonna flush and fill 2morrow, hopefully that'll do the job. And also my left fan doesnt turn on when i turn off my car, only the right one is on. is there any solution or reason on why this is happening?
rockyboy
Jan 25, 2016 06:00 PM
