having issues at 4k rpm
Old Nov 16, 2011 | 03:26 PM
neo95's Avatar
7th Gear
whats up guys, i have a 1999 acura 2.3cl 5spd with 206k miles. engine was replaced 3 years ago. spark plugs and wires replaced 8 months ago. the cat is going bad and thats the only code thats coming up for the check engine light. In any gear when i get just before 4k rpm the car starts jerking bad like a miss fire and wont go any further. any suggestions ?
Old Nov 16, 2011 | 03:28 PM
checked your oil level?
Old Nov 16, 2011 | 06:12 PM
neo95's Avatar
7th Gear
The oil is fine, if oil levels are low how would that cause this problem ?
Old Nov 17, 2011 | 10:16 AM
P0401's Avatar
because if oil level is low the vtec will not kick in and cause what you are describing
Old Nov 17, 2011 | 10:35 PM
neo95's Avatar
7th Gear
oh ok thanks for the info, the oil level is fine. any other suggestions ? im taking the car into the shop in the morning.
Old Jan 10, 2012 | 06:59 PM
Adrian Dt's Avatar
i have the same problem..
Old Jan 11, 2012 | 10:59 AM
ExShinobi's Avatar
did you ever find your issue? i was just thinking you were having a pluggd cat issue. curious what the prob was tho
fuct
May 14, 2017 09:43 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
carz0159
Sep 20, 2015 06:11 PM
Sep 14, 2015 10:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
