Hard start after driving for a while
Yeah need some help. I have a 98 cl 3.0 and this has been going on for about a week now .when I out for the day doing my errands then I come home and then try to take off again my car will start but it will not out I have to give it gas and hold it for about a min then it will be ok. Has that happened to anyone and what do I do...
thanks
thanks
Yes it has!! I have a 97 CL 3.0 and it happens to me every once in a while but is quite concerning when it does. It seldom if ever happens when the engine is cold, but from time to time i will go to start my warm engine only for it to shake and idle poorly like its misfiring. I will give it gas like you say and the idle will normalize. I believe the problem to be fuel related. I have already changed the fuel pump in my CL so it is not that. It may be the fuel pressure regulator or maybe the injectors? Both will be costly to replace. I should also note that when I run low on gasoline (the needle on E) it takes several crank attempts to build fuel pressure before it starts. Sorry I do not have an answer but I figured I would chime in as I have the same issue. If anyone has any ideas please do not hesitate to write them!
