Hadnbrake/ABS
Hadnbrake/ABS
Just 2day, my handbrake light stopped coming off when i release the ebrake. It then came off after 60km/h until it came on again and my ABS light illuminated. Heres afew pics from my road trip to Toronto 2day, had to drive my friend to airport...of to Russia he goes.
So whats going on? Solution?
no, cruise control was on before i punched it down a hill. What about the battery?BTW, car drives fine, the handbrake isn't engaged or anything..194km/h...
Im thinking its some electrical contact, maybe moisture.
Originally Posted by herbalist
i got skills
Originally Posted by YtseJammer
i have the same problem with my light, happens every few days. i'm almost positive my rear brakes aren't engaged at all.
according to the manual, an illuminated ebrake light indicates worn pads or low brake fluid level. is this true? The pads cudnt possibly be worn, had brake servic in october. Goin to check the fluid 2day
hand brake
Does your hand brake feel loose, If it does it could possibly be a seized eBrake cable. 30$ should do the trick.
My cars emergency brake light will go on periodically, I was thinking its just bad wiring or something, and it typically comes on when its cold outside or raining. Also as the car warms up it seems to go away. After the car has been running a while sometimes the light will go off when i press the brakes, but then goes back on as soon as i take my foot off the brake.
This happens to me all the time. It usually occurs when its suddenly cold or wet out. But one time, when i thought it was the same old problem, it turned out that the left rear caliper broke and all the fluid drained out from that caliper. The next morning, no brakes! The difference is, the light will stay illuminated, it won't just turn off after a while.
Had the same thing happen to me a couple years back. took it to the dealer but by that time the light wasn't on anymore (just my luck) couldn't duplicate it. Dealer sent me home with a "sure the light was on
" bumper sticker and it never happened again.
