Fog Light wiring
Old Aug 28, 2012 | 08:47 PM
PressCL's Avatar
Fog Light wiring
Can I plug my universal fog lights into a fuse and will it provide enough power. If I do this whats the best way to wire my fogs to a fuse and which one is the best. I plugged them into the parking light fuse under the steering column and the fogs did not turn on only the red light in the switch did. Does that mean that particular fuse did not provide enough power to light up the fogs. Thanks again guys for any and all help.
Old Aug 28, 2012 | 09:09 PM
bRunCL's Avatar
i wired up my fogs using a universal foglight harness that I ran into the stock harness at the firewall. required some basic soldering, nothing too crazy. i believe all of our cars are prewired for fog lights. I used the universal kit, an oem switch, got power from the battery and grounded it in several places on the chasis. Took me a while to figure out and a lot of playing around with a multimeter. You definitely could tap into the parking lights if you wanted to but I like to keep everything plug and play and as stock looking as possible so I went a different route.
Old Aug 30, 2012 | 06:07 PM
PressCL's Avatar
Where are you located BrunCL
Old Aug 30, 2012 | 09:42 PM
bRunCL's Avatar
im located in philly/NJ.
So this brown female connector comes standard on the CL. Its tucked away in a harness with some electrical tape from the factory. I was able to identify + and - and then soldered some spade connectors onto my universal harness to "jump" the brown connector. That brown plug is prewired to the blank "knockout plate" inside the car opposite the hazzard switch. When you pop the blank spot out you'll see a connector. You can plug a 90-97 accord fog switch right into that.
Old Sep 6, 2012 | 04:48 PM
PressCL's Avatar
Thank you SO MUCH BRUNCL, you are the only person on this entire forum who showed a photo of where the fog female harness is under the hood. BRUNCL is the best CL owner out there, love you man.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
