Engine nosie Part II
Old Jan 14, 2007 | 12:33 PM
kichigai's Avatar
Ok I found where the sound is comming from.
Its the drivers side of the motor sounds like it comming from around the area near or just above the trans maybe a little higher.
My past post I was explaining there was a whiring noise comming from the engine.
Any one have any ideas the noise is starting to get a bit louder and it is most definitly
not the blelts or anything on the passenger side of the motor.
Thanx in advance!
Old Jan 14, 2007 | 12:39 PM
kichigai's Avatar
Here is a link to my old post
http://www.acura-cl.com/forums/showt...o_threadrating
Old Jan 15, 2007 | 02:31 PM
kichigai's Avatar
Unhappy
Does anyone know why this noise is Happening????? Where it is????
HELP!
Old Jan 15, 2007 | 04:18 PM
TexasHonda's Avatar
PS pumps can make a whining, whiring sound sometimes. Could be low on fluild or just noisy. Some seem to be worse than others.
If the noise is there all the time, you should be able to isolate using a tube as a stethoscope.
good luck
Old Jan 15, 2007 | 04:46 PM
kichigai's Avatar
good luck
Thanx Texas where is the PS Pump?????
Old Feb 1, 2007 | 08:13 PM
sikemcl's Avatar
sick wit it!
what up homie! i guess it turned out to be trans I'll give you a call.
Old Feb 5, 2007 | 11:10 PM
kichigai's Avatar
wusp bro i called they said you werent in.
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 03:16 PM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
Koff
Sep 9, 2015 02:55 PM
