ELD (electric load detector)?? any takers?
98 cl...I recently read somthing about a "ELD" in a repair manuel is said it was located in the fuse block in engine compartment dont see one though...granted the manuel was for 98+ accord but im jus curios if anyone knows about this? im gettin a draw under load : symptom=for instance when cooling fans come on w/ heat on slight light dim,idle drop(a lil) and slight vibration.. i replaced iacv,dist.,plugs/wires,alt.... battery test was @ 27ish? idk car has these minor issues and i know it somthin stupid that will make it 100% its clean and solid+runs strong im the 2nd owner has 151,000 and worth fixin minor stuff BUT DRIVIN ME CRAZY!! i think i have c.o.c.d!
The ELD is part of the fuse box. You can't replace it without replacing the whole box. There is supposedly a way bypass it, but I've never found enough information to be able to attempt it. I have the same symptoms. If you do a search of the forums there are a few threads discussing the problem.
FYI those three small wires that come out of the lower right side of the fuse box go to the ELD. (If you're looking at it from the front of the car)
Yea kinda figured that when I looked at it! The honda man. Showed wat looked like a relay w/ two conntact coming off the left and right side and said to unscrew and take out but lookin under the hood saw a wire harness.. The 100amp and batt.. Conntacts look a lil dusty gonna spank em up tomm.. I already did all the grounds ( I could visably see) soo we'll see? I might jus cop a new batt.. And see wat happens! Ur car get a lil vibration under electrical load??
Lol yea when I put mine on u can feel it in the idle .. It's hard to explain but u can tell the signal I drawin power? Wierd?? Idk I'm do somemore investigating and try a few things tomm.
Yea mine too head lights also dash lights all that! The Acura dealer near me said they all do it? Idk about that I got the feeling they jus didn't want to deal w/ it right then.. Like they're waitin for " electrical destuction"!! I'm gonna look into a few things tomm.. If I come across anything .. I'll post!
For some reason I keep thinkin maybe the drop in the idle and draw is due to a fuel issue? Like the draw is on the fuel pump?... Idk this is drivin me crazy! Ima figured it out thoe! I have too! OR IM A FAILURE! can't have that now can we?
It smooths out if I give it gas. I want to say it idles at 900 RPM, but I can't remember for sure. I can't check now I'll have to let you know tomorrow afternoon because it's in the shop getting the windshield replaced.
Yea mine idles low at times and that's when I get shakie.. I'm thinkin my rear mount cuz it only does it on occasion ... There's a selinoid that controls the postion of the mount w/ rpm change ... Or might be slight vac leak ! But listened I got a ear for that but heard nuthin I'm spray some startin fluid around the motor tomm.. It soo wierd it only happens somtimes and others it FINE could be fuel pump to thoe under stress it kinda seems like when tank gets below half it fine too?? It's makin me nuttz.. My guy that did the timing belt said ... Coolant temp sensor could cause a idle issue cuz the iacv work along w/ coolant system... Any thoughts??? And wat happened to ur windshield?? Crazy chick w/ a brick??? Lol j/p
Btw .. Mine idles at like 750 -800 I know on the throttle body there's a lil Allen screw under the cable set that acts as a stopper and was thinkin for vibration it shook it down when my mount was broke?? Cuz if I take it up w/ the peddle to 8-9ish it's idle soo nice..and I know normal idle is 9
Hope this works
Well I found the connection for the ELD on my 98 CL auto, it is in the fuse box under the hood passenger side. I just disconnected it and turned on the car, drove for a mile or 2, the car ran fine. I just charged my battery the day before so I'm not sure it worked. Before I did that I charged the battery when ever the lights started dimming under a load, if I didnt do that it would run fine but it was just irritating. Oh my CEL light is blown so I dont know if its on. Let me know if you think I did the right thing.
bypass your eld, all your dimming issues will be fixed.
https://acurazine.com/forums/1g-cl-1997-1999-56/do-i-need-new-battery-what-blinker-462781/
Yo Mach...I jus spent the past hour studing the link to that thread u sent me.. And of course I've got the same issue so u did this ( bypass)? Could u be a lil more detailed on wat u exactly mean by bypassing it ?? I'm electrically challenged in some ways ? Jus unplug it?
Sorry - the dealer (of all places did it). Can't say how, or where it is, but i'm sure unplugging it will work. They said they removed a pin in the connector so it was "clean" Sorry, i know this doesn't help very much.
ITSJESTER
17
Dec 6, 2018 02:29 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
