EGR Valve
If you have an F22 this is what you need.
http://www.odyclub.com/forums/showth...hreadid=105896
Its for the Honda Odyssey but the same engine.
Usually you will throw a code for this one.
Also depending on your mileage Acura might do it for free as a tsb.
You have to remove the intake manifold and spray carb cleaner in the hole in the manifold and the port to the egr valve. I did it on my 99 cl 3.0 it was easy. I think the 4 cylinder is harder.
