DRL lights issue
Old Sep 5, 2013 | 09:18 AM
Sticksmith's Avatar
4th Gear
DRL lights issue
Hello i am new to the Acura and i bought a 99 Cl 3.0. My issue is one high beam and daytime running lights dont come on. The light on the dash is lit up all the time when low beams are off. I was told it could be the DRL module but no luck in locating the grey box. Would anyone have a picture or explain to me were to find the module? Or have any suggestions on were i should begin to try and fix the issue? Thanks in advance!!!!
NEWBIE Lol
Old Sep 5, 2013 | 09:36 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I don't have DRL's so I can't be of much help, but search around, there are threads about that module
Old Sep 5, 2013 | 12:24 PM
Sticksmith's Avatar
4th Gear
I found a 14 pin blue plug by steering column but the box it's plugged into is black could that be the module I'm looking for for the daytime running lights or should it not be a gray box?
Old Sep 5, 2013 | 01:25 PM
Sticksmith's Avatar
4th Gear
99 Acura CL 3.0
I found the DRL module under dash on key side of steering shaft behind the aftermarket command start!!! Fixed the broken joints on the board and everything works again!!!
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
