Cylinder Position Sensor
Old Mar 22, 2008 | 04:43 PM
Blenz's Avatar
I'm getting a CEL 9 (cylinder position sensor) on my 97 2.2. The CEL doesn't come on until the car has warmed up. I'm running a P28 using a OBD2 -> OBD1 conversion harness. I checked the wiring on the harness and it looks good. I wasn't getting this CEL the last time I started the car up which was about a month ago.
I think I can check resistance at the connector for the CYP sensor to further diagnose, but I'm not sure where that connector is. I don't really know what to do about this problem and any advice would be appreciated.
Old Mar 22, 2008 | 11:39 PM
tron's Avatar
the CYP sensor is an internal component of your distributor, so the connector is apart of the distributor connections. im not sure which ones though. also, I dont believe they sell replacement sensors, so if its bad you might have to replace the whole distributor.
Old Mar 23, 2008 | 02:03 PM
Blenz's Avatar
Thanks for the help, I'm gonna replace the dizzy and see what happens.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
mlody
Dec 4, 2019 02:11 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
