Could this be a problem with the speed sensor?
Old Mar 27, 2019 | 02:49 AM
Schmewt's Avatar
Hello all, first time poster.
I just bought a '98 3.0 cl the other day, and everything seems to work fine except the speedometer and the cruise control. With the speedometer it will work for a little while at random times, but then drop down to zero and stay there. The cruise control also doesn't work and I've read in a couple places that the two together can indicate a problem with the speed sensor. The only thing that seems amiss is that the check engine light doesn't come on. I'm not the most knowledgeable about cars, so I figured it was worth a shot to ask here. Thank you!
Old Mar 27, 2019 | 09:59 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The Vehicle Speed Sensor is the issue with the speedometer, the speedometer issue may be impacting the Cruise Control
noynek
1G TL (1996-1998)
May 21, 2018 03:05 PM
grcat
1G CL Problems & Fixes
Aug 4, 2017 11:17 AM
JackSprat01
Aug 21, 2005 11:35 PM
NighthawkBlack
Oct 12, 2000 10:57 PM
