car still shakes after alignment
Old Oct 15, 2009 | 01:10 PM
f22vtec's Avatar
so i thought my car would stop shaking when i got my alignment but i was wrong. I can really feel it pretty much wobble side to side when go at slow speeds. Any ideas?
Old Oct 16, 2009 | 12:15 AM
jessec87x's Avatar
8th Gear
Did you get your wheels balanced because mine did the same thing..I had that done it went away. You always could have a bent rim
Old Oct 16, 2009 | 01:12 AM
f22vtec's Avatar
i know my front tires got balanced idk about the rear though i bought them off h22euror im sure they were tho.
Old Oct 16, 2009 | 01:36 PM
OttaWacK's Avatar
less n00bin more g00glin
Might not be balance, but your tires could be bulging citing broken belts in your tires tec. Could just be the tire losing the "roundness." You can leave the tire on the car and with a chalk and jig you can find if there are high and low spots on the tire. This can occur laterally and radially (vertical). if you have a dial indicator you can measure if there are any discrepancies. Technically, tire specs on cars should not exceed 25-30 thou.
Old Oct 16, 2009 | 02:32 PM
f22vtec's Avatar
thanks man ill look into that asap
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
GhostTL09
Sep 19, 2015 01:57 PM
Zonian22
Sep 2, 2015 08:19 AM
