Another Trans Question
Old Jul 14, 2013 | 05:31 PM
darkcrave's Avatar
1999 Acura TL
3.0
1-Owner
Car is Beautiful!
Test drove it trans was fine. Next day it started acting up. Checked the Fluid. BLACK. I clean the filter. did the 3x3 with Honda ATF. Test Drove it about 20 miles and it was fine.
Now took it up a hilly area and its having a hard time going from 2ed to 3ed.
I just want to know if the tranny is bad, or do I need to do one more flush or if something I missed is wrong
Old Jul 14, 2013 | 05:32 PM
darkcrave's Avatar
Just over 160k miles
Old Jul 15, 2013 | 05:20 PM
bRunCL's Avatar
Was there any metal shavings on the drain bolt or in the fluid itself? The internal clutch packs could be worn down which means you'd need a trans rebuild. Mine was black from about ~120k. I was scared that changing the fluid at that point would do more harm than good. Trans finally gave out at 178k without any warning. Basically what I'm trying to say is only time will tell
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
datadr
Sep 12, 2015 09:12 PM
