All (6) cylinders have error codes...
Old Mar 13, 2014 | 10:09 AM
RugDoctor42's Avatar
About a month ago, my '98 CL 3.0 started running really sluggish/sputtering. When read, all 6 cylinders have error codes. I thought it might be the Ignition Control Module or the distributor. Took the ICM to O' Rielly's and they don't have the correct adapter to test it and neither does the dealership. What to do? If I buy a new one (around $100) and plug it in, it's mine to keep if it's the problem or not.
Old Mar 13, 2014 | 11:58 AM
acrdr's Avatar
can you post all the cel codes?
Old Mar 13, 2014 | 12:38 PM
I'd have to put the ICM and the distributor back in to do so. I could, if you'd think it will help.
Old May 19, 2014 | 06:57 AM
TeamAc03's Avatar
G
Old May 19, 2014 | 07:01 AM
TeamAc03's Avatar
I have a similar problem, I have a 01 acura cl n im having misfired in cylinder 4,5,6.. im also having a code p1399 n p1456.. the car shakes n make little rattle sounds n my CEL is on.. Wat can be tg e cause?
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
