Alarm Problem...Help
My 97' CL 2.2 Factory Alarm has started the past couple days just going off randomly and went off at 4am last night...I went out and opened the door and then locked it and 2 mins later it went off again...I had to leave the door unlocked the rest of the night to stop it. I read that others have had this problem but no real solution. I don't care for the Alarm that much at this point and just need a cheap a quick solution. Is there a way to just disarm the alarm? Or is it a cheap thing to fix? I just reall wantt o be able to lock my car doors without having the alarm go off. Thanks for the help.
worst comes to worst, just unplug the security box then plug it back in when you use the car. at least the only way somebody steals your car if they plug it back in or its gets towed.
if you just want to lock your car and no alarm activated then just look under the passenger seat, unplug those two plugs there and you got it done and you can unlock and lock your car with the key , i have my factory alarm upgraded i did it myself and turned it into a dual shock sensor too anyways hope you got that fixed
Jul 16, 2017 07:33 AM
