acura cl
acura cl
Hi people I just pick up a 1997 acura cl for 500.00 so far I found that the window woun't go down on the dr side motor works but thats it and the door woun't open from the inside.Got two top ball joints to go in and one outter tierod. Seems to be it for now can you tell me what to look for you problems any reply is great O the heater only works on high speed.Thanks for reading this new to this form later.
acura cl
It's a 2.2 drove her around for a bit seem's to be good but shs is not regersted to mt yet.Needs to fix the door hates to take the pannel off cause hard to put back on right cause its not reck up or anything.When I saw her I new she was taken care of.
if the door wont open, then your connecting rod inside the door that goes to the inside handle could possibly be bent or broken.
Does your window work period? If it goes up, the look at replacing the switch. If it doesnt work at all, change the window regulator.
Try this:
Turn the car to ON (II) but do not start.
After one minute, push both auto and off at the same time. Tell me what shows up, be it A/C on, the second bar for the fan operation, be specific. This is the self diagnostic.
Try this:
Zonian22
Nov 14, 2015 01:20 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
sockr1
Oct 1, 2015 01:31 AM
asahrts
Sep 4, 2015 05:55 PM
even with those probs $500 is a steal. 2.2 or 3.0?
