ABS light
Old Nov 23, 2006 | 09:40 PM
CLsoldier's Avatar
ABS light
My ABS light has been on for a few days now. I'm wodering what are some ABS problems that cause the ABS light to come on.
Old Nov 24, 2006 | 06:05 AM
TexasHonda's Avatar
ABS self-diagnostics are the best way to determine the problem. Short the 2-wire (red & green-blue) service check connector (SCC) under the glove box and dash, turn keyswitch to ON, and read the short flashes. Codes are flashed as tens digit-1sec pause- units digit, w/ 5-sec pause between multiple codes are repeat of single code. There is a single digit code 1.
Do you hear the ABS pump come on at startup and pump till ABS light illuminates?
Post back code/s and I can supply some guidance on repair.
good luck
Old Nov 24, 2006 | 06:32 AM
$peed])emon's Avatar
Si says "shut the fuk up"
how do u short the wires again?
Old Nov 24, 2006 | 02:30 PM
TexasHonda's Avatar
Connect a bare wire between the two sockets of the connector to short.
good luck
Old Nov 25, 2006 | 10:48 AM
CLsoldier's Avatar
It's weird. I got my tires rotated and balanced yesterday and my ABS light is gone now.
Old Nov 26, 2006 | 07:07 AM
TexasHonda's Avatar
ABS checks for fault each time ignition is turned ON. If the fault disappears, the ABS light is not illuminated.
You could well have a dirty wheel sensor. The vibration and shock to the wheel from removal/installation may have dislodged enough dirt/grime to cause the sensor output to be adequate to avoid a wheel sensor fault. It may or may not return.
Wait and see. Sometimes problems resolve themselves. I've learned that jumping quickly to repair a non-critical fault can be costly and sometimes un-necessary.
good luck
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
