99 Acura cl 3.0
Old May 13, 2015 | 04:17 PM
Red30cl99's Avatar
99 Acura cl 3.0
I'm a noob and need major help.. I'm not even sure if the cl commnuity is still on this but my car is starting to slip alittle . It jumps alittle going from park to 4th and form first to second. The guy at the nearest mechanic shop checked the fluid , seen that it was black, and just automatically told me to get a new transmission. The car currently has 260k and I'm not sure what the last person did matinance wise . If anyone is near me or can at least guide me.. I'd appreciate it .
Old May 14, 2015 | 12:13 AM
musiclevelz5's Avatar
Red where are you located? I deal with these trans all the time. If your close I would love to drop by and help with some feedback.
Old May 14, 2015 | 08:03 AM
Red30cl99's Avatar
I'm out here in Long Island ny. Thanks for the quick reply
Old May 14, 2015 | 11:26 PM
ok thats a bit far from me. im in the midwest. First thing I would do is get a case of Honda dw1 from the dealer or amazon and perform a drain and refill. You need to get that old cruddy particle filled fluid out of there!
Old May 15, 2015 | 08:42 AM
Red30cl99's Avatar
I heard it can be a solenoid problem as well.. When I went to the mechanic he checked the fluids .. I seen that they were pretty dark, but right off the back he tells me to get a whole new transmission.
Old May 15, 2015 | 04:51 PM
The mechanic wants to sell an easy job where he can make good money.
Trying to diagnose a trans issue is different for every case and likely takes many hours and sometimes you cannot find the problem. Likely something he doesnt want to do.
First I would get new fluid in there asap and then we can touch base on the solenoids on what to do.
Old May 15, 2015 | 05:08 PM
Red30cl99's Avatar
Getting that done tomorrow . I will keep you posted and thanks for all the help as of now!!
Old May 16, 2015 | 07:45 PM
Red30cl99's Avatar
Got fluid in today.. Doesn't really slip anymore but it still jerks when at a stop.. Ex. When I go from park to drive or drive to reverse. Any further instructions ?
Old May 17, 2015 | 12:10 AM
Drive the car a couple hundred miles and then do another drain and refill.
Did the jerking stay the same, get worse or subside a little after you put the new fluid in?
Old May 17, 2015 | 10:59 AM
Red30cl99's Avatar
It actually did drop dramatically, here and there it's really noticeable . I drained and filled, also let the car run for about 30 minutes yesterday before driving it.
Old May 17, 2015 | 12:09 PM
If it helped the jerking then doing another drain and refill will most likley help even more! That is very good to hear.
Old May 21, 2015 | 10:28 PM
Red30cl99's Avatar
Problem came back even more noticeable.. Last thing I wanna do is buy or rebuild the tranny.
Old May 22, 2015 | 03:54 PM
Ok next thing to do is test solenoids for correct resistance and proper valve movement.
Also the screens need checked for buildup and cleaned out if necessary.
The TL side has a couple of diy and is very similar. Here is link.
https://acurazine.com/forums/third-generation-tl-2004-2008-93/diy-solenoid-filter-clean-testing-858525/
The link only shows the linear solenoid being taken off and cleaned but you apply the same testing to the other solenoids on your trans as well. Some of them have different resistance readings tho.
Zonian22
Nov 14, 2015 01:20 PM
sockr1
Oct 1, 2015 01:31 AM
asahrts
Sep 4, 2015 05:55 PM
LAMike240
Sep 3, 2015 04:35 PM
Mikehxbx
Aug 31, 2015 10:17 PM
