98 CL Clutch stuck on floor no pressure
Old 05-10-2011 | 10:12 AM
Ozzieninja's Avatar
Hey guys, So I went to start my car (98 cl 2.3) this morning and pressed the clutch and it did not come back up. First I checked my reservoir and filled it. Next I replaced the clutch master cylinder and still no pressure sending the clutch back up so I replaced the clutch slave. I have bled the system but still with the slightest pressure on the clutch it goes to the floor and stays. Now I'm tracing the lines and in between the master cylinder and the slave it is hard to see but it seems to enter some sort of device...is this my problem? I don't know what it is and as I mentioned it is hard to see without taking a ton of stuff apart. Any help with this would be appreciated. Thanks
Old 05-10-2011 | 12:49 PM
P0401's Avatar
I had an accord that had a leak and all I ever had to do was put fluid back in the slave cylinder reservoir and pump it back up and it would work. I am not sure what else it attaches to but will watch this thread to see the answers (as the accord and now the CL is the only two foreign cars I have owned)
Old 05-19-2011 | 05:22 PM
Davids99CL's Avatar
it really sounds like you have air in the system i know you bled it before but maybe after all the parts you replaced you didnt tighten one of the lines that its still getting air in...if you did all that then most likely its just a bad Clutch master cylinder
Old 06-03-2011 | 05:03 PM
redcl62188's Avatar
USDMYA1
I had the same issue. The line that goes from the slave to the tranny is bad.
Old 06-06-2011 | 03:55 PM
Project_CLean's Avatar
MMkay.
I vote clutch master, will it come back up if you pull it? turn the car on and listen for noises if you can, maybe somethin snapped near the throwout.
Old 06-18-2011 | 11:11 PM
Ayu688's Avatar
Where is the slave cylinder reservoir?
Old 06-20-2011 | 08:36 AM
MMkay.
slave cylinder does not have res. only clutch master which is next to your brake fluid reservoir, real small. and if you were asking where they are ; clutch slave is on tranny, clutch master on firewall
Old 07-08-2011 | 01:39 PM
Acura1997Cl's Avatar
only time i ever seen that was on a '96 honda del sol and it was a clutch master cylinder that had to be bolted on basically behind the clutch pedal underneath the dash and then just bleed and adjust the clutch
Old 09-21-2011 | 08:47 AM
cl-baller201's Avatar
2.2CL owner
it just happen to my 97 CL the clutch stays on the floor, it comes up if I pull it up.
Old 09-21-2011 | 06:57 PM
reksht's Avatar
sooo... i read your thread before i left work to go pick up my car thats been sitting at a shop for 6 months... had to install my right rear suspension to get it running.. started right up drove it around and BAM... SAME SHIT HAPPENS LOL
Old 09-21-2011 | 09:29 PM
reksht's Avatar
installed a master clutch cyl.... WWRONG... its the slave cyl.
Old 11-05-2011 | 02:50 PM
2nd Gen 02 Type S's Avatar
Okay I'm having the same problem I brought it from so kid he told me it had a stage 4 clutch in it which it does cuz I pulled it apart and check it but I bleed the Clutch slave air came out n than fluid tighter it up clutch goes straight to the floor so now I need to replace the master
SidhuSaaB
05-30-2020 12:40 AM
Quick Reply: 98 CL Clutch stuck on floor no pressure
