98 2.3 Power Steering.
Old Feb 17, 2011 | 09:35 AM
AnalyzeFaith's Avatar
I had my uncle replace the the belt that goes to the alternator. He had to remove the power steering belt to get to it, in the progress the power steering pump was lowering down so he hit it with something to make it start lowering. ANYWAYS, after that was done we got the belt on and everything... Power steering stopped functioning, it just keeps making A LOT of noise and when I fill it up it just drains back down. What caused this? Was it cause he hit it? Also, what can I do to fix it or what should I look for? Thanks a lot.
Old Feb 17, 2011 | 01:08 PM
Eric98Cl2.3's Avatar
I use my turn signals.
are all the hoses connected? you may have knocked a hose loose.. not sure why it would drain right back out unless it's leaking from somewhere.
Old Feb 17, 2011 | 01:09 PM
oh and make sure you're using honda power steering fluid. You shouldn't use regular power steering fluid.
Old Feb 18, 2011 | 11:45 AM
I dont see any loose hoses. I check them all out. I even drained the fluid and replaced it with lucas PS anti leak. Still loud... The pump is making a loud noise and the PS keeps making bubbles. Could it be the pump itself? Or is it an O ring?
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
