97 OBII code strange- light on
Old Mar 9, 2007 | 07:24 AM
notthd's Avatar
4th Gear
Hey all, I'm new to the forum and have a 97CL 2.2 question. Our car Check engine light is on but when I pull the codes it does not display in the normal 4 digits. It leaves digits blank. The three codes are ( the _ are blanks) 04_ _, 3_ _8, 10_6, If anyone can tell me what these are or another way I can check what the code means thanks, I can clear the errors with my OBDII tester but they come back- the car is running less than perfect...
Old Mar 9, 2007 | 11:14 AM
saiko_cl_duck's Avatar
you are pullling them with a scanner?
Old Mar 9, 2007 | 11:17 AM
asianspec's Avatar
use the OBDII scanner at autozone then they will tell you whats wrong.
Old Mar 10, 2007 | 06:10 AM
TexasHonda's Avatar
Try getting the OBD1 codes by shorting the service check connector and reading the flashes; long flash for 10's digits and short flashes for units digits w/ 5 sec pause between successive codes.
good luck
Old Mar 11, 2007 | 09:40 AM
notthd's Avatar
4th Gear
I am using my own ACTRON OBII Scanner, and yes it is working properly. I scanned my truck with the MAF disconnected to force a code and it did as expected. Its strange that the Acura is not posting a full 4 digits. Is there a way to check the codes not using a OBDII scanner?
Old Mar 11, 2007 | 09:41 AM
notthd's Avatar
4th Gear
Thanks for the info....Where is the service connector?
Old Mar 11, 2007 | 11:34 AM
grey connector bolted under the drivers side kick panel.
look at post 4 in the noob guide, it has all you need to know about what each code means
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
