97 CL rough auto transmission shifting
Old Aug 31, 2008 | 11:35 AM
plunix's Avatar
My automatic 1997 cl with 160,000 km on it shifts pretty roughly from 1-2 and from 2-3, almost like the cars getting seperated from the tranny haha
should i replace the transmission oil to help reduce wear, what kind do you recommend, what steps can i do on this downward spiral of my tranny?
Old Aug 31, 2008 | 01:24 PM
Nakamichi's Avatar
~[ô¿ô]~
Did you check to see if your TCM/ECM stored any codes? It could be a faulty electrical component.
My tranny was going nuts, with rough and erratic shifting. Since the D4 light nor the Check engine light did not blink/illuminate, I though the tranny was done. But I checked for codes and sure enough it said the 2nd/3rd clutch pressure switch was faulty. Switched that out for $50 (approx.) and it was back to normal.
Old Aug 31, 2008 | 07:09 PM
TexasHonda's Avatar
Any work on the throttle body? If the throttle cable is misadjusted, the shift quality can be dramatically affected.
You might consider downloading a 94-97 Accord manual from hondahookup.com. There is a tranmission symptoms chart that is quite extensive that may help.
Sometimes a drain/refill of trans w/ Honda ATF fluid will improve performance. A 2nd drain/refill will further dilute any old fluid.
good luck
Old Sep 3, 2008 | 08:12 PM
plunix's Avatar
i modified the intake half stock half makeshift intake.... right where it connected to the old airbox i added a different setup to add a performance filter, texashonda if the filter is loose could it be the issue?
mada51589
Jan 9, 2025 04:40 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
