97 cl cv halfshaft / axle replacement problem
I just spent the entire fucking day replacing pads, rotors, and axle shafts on both sides on a MANUAL trans 97 2.2 cl. I spent all day because it was an ohio car with mucho corrosion making the whole thing a monster of a bitch.
My question is this, when removing the axles from the transmission an oil pored out with the axle shaft, Not a ton but a total of about half a quart. I know I'm a complete newb, but I'm not a mechanic. To me it looks/feels like engine oil and after the install i was about half a quart low on oil. Im just making sure this is normal or if its not motor oil then what do i need to fill up to replace the lost fluid?
Thanks guys.
Thanks guys.
That is transmission fluid. Go to the honda dealer and buy some for about $8 a quart since you only need about 1/2 or 1/4. You will also need a pump to get it into the transmission filler hole. Make sure the car is level when you fill it. Pump in fluid until it overflows out.
justin7779
12-25-2015 10:33 PM
