*engine Code****
Old Sep 1, 2005 | 07:55 PM
swain's cl's Avatar
*engine Code****
I am throwing a code 1259 i have a feeling it is running rice as hell. took plugs out and yeah Black real black. but i am not sure yet. but i am thinkning that;s what it is. i fyou have any info just let me know
Old Sep 2, 2005 | 10:29 PM
wilp99's Avatar
is 1259 something your computer gave you, or is that autozone?
Old Oct 2, 2005 | 05:04 PM
ruin's Avatar
hey , igot oil in my plugs and my car wont start. help!
Old Oct 2, 2005 | 10:16 PM
wilp99's Avatar
could be bad rings.. could be cracked head. could be bad valve guide seals or valve guides. start by doing a compression test. get the compression guage from autozone. screw it in to the spark plug hole remove all the sparkplugs, turn the engine over, the needle will jump. let it jump 7-8 times and it should settle out to a final number. write down the number starting with #1 sparkplug, and continue down the block to #4. if the number is more than 15% difference between two you have a problem if they arent then its something fuel related. are you sure its oil? could it be carbon. if it smells like gas then its carbon. also try replacing the plugs.
Old Oct 4, 2005 | 03:36 PM
ruin's Avatar
car doeesnt turn at all can i still try the compression test. i replaced the plugs they got wet with oil.
