Prelude short shifter mod
Basically the only part from the prelude is the shifter itself as far as I can remember, you're switching over the flat plate things on either side of the round part at the bottom of the shifter, and that little squared thingy on the end that goes into the plastic triangle part. Hopefully I'm not confusing you with all these shapes lol.
Don't forget you have to bang down or cut off the tabs on the CL shifter plate too or you won't be able to get into gear properly.
No problem, better you do it right than have to take it apart again because you find out you screwed something up lol.
If you're talking about the bolt with the curved thing on the end of it and that round sleeve, you'll have to get that from the dealer if it isn't already on the shifter. It's a pretty stupid price for a bolt if you get it from them (I had to) but not much else you can do about it if you want your shifter to be tight and not have a bunch of play.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
guyvelella
Sep 30, 2015 11:02 PM
Thanks man, I'll just keep an eye out for that bolt/collar deal when I'm yanking the shifter out. Ha! If not, I'll go donate to the stealership.
