.pdf - Power Steering Fluid Change!
Old Oct 19, 2008 | 09:51 PM
iansanderson's Avatar
'99 2.3 CL
several members have requested the SM instructions on PS fluid replacement. sooo, here is the PDF for changing your power steering fluid in the 2.2/2.3. (3.0 similar). You will need 2 bottles from the dealer and an assistant to start/stop the engine.
Oddly, the manual does not recommend an interval, so I recommend performing this service every 60-80k mi. If you have access to some misc. hoses and connectors, it helps a lot. Jamming a container near the belts is kind of a pain and unsafe, so I connected a nice long tube from the return hose to a container I had sitting comfortably away from the drive belts. The return hose is not under high pressure, but will force the fluid out very quickly once the engine is started.
As always, PLEASE only use Honda PS fluid.
Fluid Replacement Instructions
(pdf)
Old Oct 20, 2008 | 07:41 PM
Mach30SiR's Avatar
Bagel Bomber
Thanks!!
Old Oct 21, 2008 | 01:04 PM
Newbee's Avatar
um, everytime i change my PS fluid, i just pump the old fluid out with a pump from these types of bottles
and then put my new PS in. quick and simple.
mada51589
Jan 9, 2025 04:40 PM
TL-Rocket
Apr 29, 2023 02:33 AM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
