Easy weight reduction on the CL
Old Sep 11, 2009 | 06:43 PM
kmatthe2's Avatar
Here is my mild weight reduction list for my 3.0 CL
Just posting it up if anyone wants to do some mild weight reductions easily on their CL.
126 lbs
FRONT: -33 lbs
empty windshield washer reservoir: 5 lbs
braille battery replacement with custom mount: 21 lbs
glove compartment plate: 2 lbs
air intake resonator: 5 lbs
MIDDLE: -6 lbs
floor mats: 6 lbs
BACK: -87 lbs
Rear tow attachments to chassis: 2 lbs
Spare tire: 30 lbs
misc tools/junk: 2 lbs
undercarpet spare tire well supports: 6 lbs
reduced gas tank fill (9-10 gallons less than full): 55 lbs
Added spoiler: +8 lbs
Can't find anything else reasonable to take out, anyone have any ideas?
(I don't want to start replacing all the body panels with carbon fiber--it looks ugly)
I'm thinking lightweight wheels at some point
this is addicting
Old Sep 11, 2009 | 07:52 PM
f22vtec's Avatar
i wouldn't take out the floor mats unless u want brown carpet...and the spare wheel? no way i just got a flat lol if i didn't have the spare tire i'd be screwed. pretty interesting ideas though.
Old Sep 11, 2009 | 09:07 PM
Polaris573's Avatar
1998 CL 3.0
Maybe pull out some of the insulation/carpet in the trunk? Would probably lose you a few pounds.
Old Sep 11, 2009 | 09:53 PM
kmatthe2's Avatar
ehh floor carpet can always be shampooed
thinking of getting a cheap 2lb air pump to fill and a can of fix a flat to replace the spare
of course if i ever went for a trip i'd put the spare back in
I could def lose some carpet in the trunk but i estimate no more than 4lbs for all of it. Plus i want to take more weight off the front before i do anything else in the back to keep the weight ratio about the same
Old Sep 11, 2009 | 11:04 PM
incredulous1's Avatar
lose some weight! ahaha j/k
lightweight wheels would be the way to go. faster acceleration plus less weight on all corners. and itll look better. win on all parts
Old Sep 12, 2009 | 11:07 AM
732xghost's Avatar
this is my kinda thread. ill post all my weight reduction ish after work.
Old Sep 12, 2009 | 05:19 PM
Tehvine's Avatar
6spd FTW
Easy weight reduction? Ditch the girlfriend.
You could ditch your sun visors, trunk plastics / carpet.
Old Sep 12, 2009 | 11:32 PM
kmatthe2's Avatar
Ditching the girlfriend is a bit drastic, plus she actually uses the sun visors
I actually took out the wooden/paper panelling things from under the carpet in the trunk, it was the bulk of the weight and keeps the trunk interior still looking nice and stock.
Old Sep 13, 2009 | 01:27 AM
mattastick's Avatar
Pull the rear seats and brace behind them? I did it the other day for audio purposes, and there's probably 20 or so lbs there total... Hell, there's about 5 lbs worth of 10mm bolts holding the rear seat brace into the car...
Old Sep 13, 2009 | 01:31 AM
Gnate's Avatar
Custom User Title
stupidity on a stock car.
Old Sep 13, 2009 | 02:50 AM
a2ndragoon89's Avatar
joe rocks c2s :D
remove your passenger, replace your driver seat with a lighter seat, take out rear seats
Old Sep 13, 2009 | 02:51 AM
joe rocks c2s :D
use stickers for emblems...save 8oz
Old Sep 13, 2009 | 02:54 AM
take off your a/c assembly
Old Sep 13, 2009 | 03:58 AM
C4PT41N_73TH47's Avatar
98 3.0CL
haha^
have you noticed any improvements after removing all the stuff?
Old Sep 13, 2009 | 01:49 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Search around, there was a member back in the day that posted up weight reduction ideas and actually cut all the insulation out of the floor to loose weight as well. Taking out the floor mats for weight reduction is a bit silly if u ask me though...
Old Sep 13, 2009 | 04:10 PM
mattastick's Avatar
This whole thing's a bit silly if you ask me... I mean our cars weigh what, like 3300lbs stock? Not a whole lot you can do to make it really fast short of Cocoa and his sick CL. Now, I'm probably going to get yelled at by the H22/23 crowd, but you car's still a 4 cylinder dragging around 3300+lbs... Me personally, I know my CL will never be fast, so I keep adding stereo goodies to it...
Old Sep 13, 2009 | 04:20 PM
DaInFaMMuS1's Avatar
my 4 cylinder drags around like 3000 lbs and i still smack 3.5 cyl 6cilinders like maximas and altimas, etc.
Old Sep 13, 2009 | 04:33 PM
kmatthe2's Avatar
I think curb weight is around 3200.
Almost everything removed individually may seem silly but it's all stuff I don't need and it adds up.
So a 3200lb car with a V6, I don't use it for track racing or anything but its nice to be able to pick up speed from stoplights with less weight on the pedal.
I've dug around all the forums out there even outside of azine I don't think theres a whole lot more that can be taken off without any ill effects.
A full interior with climate control is a lot nicer than the same car with an ugly metal interior in the back and no A/C to save maybe 80 lbs.
Old Sep 13, 2009 | 07:14 PM
732xghost's Avatar
when i had my F22 i weighed my car at the track and it was lighter than my friends BB6. i weighed in at about 2,8xx. i weighed my recently with the H22, no AC or P/S, bunch of other misc crap removed and i was like 2,9xx almost 3,000 even.
Old Nov 2, 2009 | 09:09 PM
97vtech2.2's Avatar
5th Gear
i just purchased a cf hood for my cl anyone have any idea how much weight that will reduce?
Old Nov 2, 2009 | 10:53 PM
(Mid-Atlantic)
about 25 lbs
Old Nov 3, 2009 | 08:04 AM
mooseknuckle's Avatar
5th Gear
request for weight reduction
hey man i have shaved a whopping 250 lbs off mine.. heres how,
remove all under motor plastic
remove all air box components (you have to remove front end for this)
spair tire
all air bags and wiring
all metal supports for battery
remove all cowel covers
remove radiator overflow
remove windshield washer motor and container
cut out cats and resonator
Old Nov 3, 2009 | 08:29 AM
Polaris573's Avatar
1998 CL 3.0
Wow removing airbags is hardcore. I wouldn't even do that if my care was solely a track car. Cost vs. benefit is way too high .00001 seconds faster vs. vastly increased chance injury/death.
Old Jan 4, 2010 | 12:58 AM
on1wheel01's Avatar
yea wow i dont see how shedding a few pounds is really going to make a ton of diff. But hey it's ur ride. Just get some juice or something.
Old Jan 7, 2010 | 01:04 PM
Lawlergaggzorz's Avatar
i shaved about 130lbs by taking my doors off. should shave another 20lbs when i remove the trunk lid...
Old Jan 7, 2010 | 05:38 PM
saiko_cl_duck's Avatar
wow.
I hope your not serious.
Old Jan 7, 2010 | 05:57 PM
yeah that was total sarcasm. sorry for the confusion.
Old Jan 7, 2010 | 09:01 PM
use red text next time man, people might actually think you're serious....
Old Jan 7, 2010 | 09:31 PM
stlswagger's Avatar
Man some of you guys are extreme on weight saving for a non-track car lol. I removed my spare (that's what AAA is for) and used that space for my amp.
As for off the line speed, that's what performance mods are for IMO. But this is coming from a guy who still hasn't even hit the redline because I'm thinking she's pretty fast without redline lol
Old Mar 9, 2010 | 11:28 PM
raceready08's Avatar
99 ACURA CL
replace stock rims with light weight racing rims is also an idea.
Old Mar 12, 2010 | 11:45 PM
on1wheel01's Avatar
get another cl and strip it all carbon fiber seats and such
Old Mar 12, 2010 | 11:56 PM
shnee's Avatar
Land of Pleasant Living
Fill your tires with helium. Fill your cabin with helium balloons. Tie helium balloons all over your car. Put stickers on your car that say helium. Get a license plate that says helium. Say "helium" when you're driving your car. Let's try it right now, together. Helium.
Feel lighter, don't you? Helium.
Old Mar 13, 2010 | 10:25 PM
(Mid-Atlantic)
get out of here with that bs
Old Mar 13, 2010 | 10:28 PM
shnee's Avatar
you love it!
Old Mar 14, 2010 | 12:23 AM
mitch14's Avatar
CL in lawnmower status
i TBH
one of the most pointless threads imo, less gas in tank is like almost half of all his savings
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
knight rider
Mar 4, 2016 08:59 AM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
h22lude
Sep 27, 2015 06:22 PM
