zex smarbox resetting?????
nothing
every couple times i turn my car off then back on, the smartbox will reset itself. when i hit the gas pedal it will start clicking? any ideas what the problem is?
A-CL Post Whore w/N2O
I had this problem with my Zex dry kit. I've also heard (through my Uncle) that a number of VW owners are experiencing the same problem!
I never resolved my problem (sold the dry kit and got a wet kit), so I don't know of the solution. My guess is to check the wiring (especially) to the TPS sensor. I mention this because if the management unit looses the TPS signal, it will default to set-up mode (which requires you to reset the management unit).
Good luck!
Good luck!
fastest time 13.4@107 !!!
Re: zex smarbox resetting?????
if you disconnect your battery, that is the way you program your box using a code with your ignition and gas peddle..
it's normal
nothing
i cant check right now cuz its pouring rain but the tps is the black or red wire. also when it sprays now im only gettin probably 20 hp (theres hardly any difference)and the bottle is full, ill check all the wires tomorrow when i can see in the light. hopefully somethings just loose.
when i said it clicks i meant it clicks continously for however long i hold the gas pedal down. ???
WTF
i have no idea... never heard of that before
