In your opinion?
Revelation 3:15-17
In your opinion?
Which do you assume works best at restoring a scratched/dull headlight lens?
1. http://www.noscratch.com/novus/number3.shtml
2. http://lensrenew.com/
Has anyone in here ever used any of these two products?
Post before and after pics. Thanks!
GLOBO Gym Spokesman
https://acurazine.com/forums/showthr...ight=headlight
I used a similar product. Worked pretty good for the price. Unfortunately they re-oxidize quicker and are now hazey again. Not as bad but not as good as they were.
There is a product I'm been trying to find. I had a link but lost it. It was a cover you put over your headlights, like an acrylic film. You first wet sand and buff the headlights to get a great like-new finish then put these on and they bond with the plastic preventing further oxidation and scratching. If anybody know what I'm talking about speak up and let me know where those are. They were like $50-$60 I think.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by CL Platano
Buying a new one at the dealership
Revelation 3:15-17
Originally Posted by Katana18
Wetsand and buff em out, thats what I used to do before I bought new ones. Thats also what I used on Ahnulds choppa when I detailed it.
Sr. Eric "The Great" has returned
It's about freaking time. I was beginning to think that you would
never return.
Good to have you back.
One of my headlamps was very hazy and I did the wet-sand procedure. I started wetsanding with 400 grit and then moved to 600 grit and then to 1200 grit. It helps if you put some dishwashing detergent into the water when you dip the sandpaper. Also - use a good, solid sanding block (from Home Depot). After that I used the Meguiar's plastic liquid polish and the headlamp looked good as new. After a few months and it still looks good...
2.2 auto and coping
i started to wet sand...mine wasnt real hazy...just that acrylic shi* it commin off.
just did one side a little. 1000 then 1500 couldnt find 2k so i just used plastic polish then i waxed it.. way better than before..still some acrylic haze.....
when i have time will do it better...
as for lube...he he...spray bottle with a cap or more of car wash soap..
