Yet Another Foglight Question
Old Jan 28, 2004 | 01:29 AM
98CLChick's Avatar
I did a search on this, I just can't find the answer that I'm looking for.
I've read that all CL's come prewired for factory fogs. I have the factory switch, but I want to get PIAA's. So can I use the wires that are already there for the piaa's, or do I have to run new wires to the factory switch? If I can use the existing wires, how exactly can I splice the wires for the piaa's? I've found some instructions on here on how to wire in the factory fogs, but I need to know how to wire up those piaa's.
Thanks!
Old Jan 28, 2004 | 08:06 AM
joeshmoe's Avatar
My Home Planet
You would still need the factory fog light wiring harness that extends to the area were the fog lights would be mounted. Then, you'd have to actually cut off the connectors of the factory fog light wiring harness and hardwire the piaa's directly to that.
I'm not even sure if it will work though.
Old Jan 28, 2004 | 08:34 AM
tightac1's Avatar
GOT AIR PPPPSSSSSSTTT?
yes it will work as long as the wires are there and then before you hook them up you need to turn the switch on and get a test light and sure you hook up the right wires to the fog light. piaa's have a blk and white wire and the white is pos+ and black is neg-
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
