Wondering
Old Dec 6, 2001 | 12:39 PM
OnCeASaiNt's Avatar
Wondering
i was wondering if anyone could give me ....in depth instructions...on taking the door panel off...to change the security light....if anyone can let me know....Thanks!!
Old Dec 6, 2001 | 01:03 PM
acura2.2vtec's Avatar
I use a condom?
I emaild those instructions a while ago to someone here. Maybie they still have it? If not I'll do it tonight if you give me your email.
Old Dec 6, 2001 | 01:32 PM
1StGenCL's Avatar
958 & 991
I just took one screw out from the door pull and one from under the windows control. Than i just popped the very bottom corner and side of the door panel off to access the light. There is a screw that holds the security light in which i didnt know about so i just yanked it out ripping the screw loose. I know, not a good idea because now i have it ghettofied with super glue to keep it in place but you cant see that it is glued at all. Im going to get a new one from my dealer soon though. You should be able to unscrew it and pull the security light out the side of the door panel. There is a black plastic piece that pops off the security assemble and than you will see the LED. Then you will see two wires coming from it (red & yellow i think) I cut them and hooked up my varad LED right to them I just used crimp connectors. I originally thought it was red to red wires but it was the opposite. Good luck
Old Dec 6, 2001 | 02:58 PM
OnCeASaiNt's Avatar
OnCeASaiNt@aol.com
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
Bielikb96
Sep 28, 2015 10:45 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
