Window info
Window info
Most, if not all of you have had the window just quit working at somepoint, and it's usually at the worst time possible, so hear is a little help.
My window regulator is dead, what do I do?
-saiko_cl_duck-
-94-97 accord window regulators work.
-They're one piece, not two seperate items.
-if it's slow, lube it with silicone spray.
-if it's still slow, look to replace it.
-if the window falls down and you hear grinding, the regulator is toast, take off the door panel and prop it up with a bar or rubber wedge.
The DIY to removing the door panel is in the DIY section, along with a DIY for replacing the window regulator, see link
Window Regulator DIY
-saiko_cl_duck-
bamaborn74 (02-11-2014)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
