Will this fit?
No Show All Go
Originally Posted by Smalls
Double check that...
The 3.0 corrolates with 94-97 Accord V6 on most parts
NOHING IS RELATED TO THE 94-97 V6. it is the 98+ accord v6 you need parts for. also if you get aftermarket plug wires (which dont help anything) dont use bosch platinum plugs. the wires will pop off.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
NAWWWWSSSSSS
1 Post
If you don't know the answer, or don't own a 3.0, don't answer And yes, it's the 98+ accord thats' our 3.0.
Insert Sarcasm Here
Im pretty sure that I bought a window regulator for a 94-97 Accord.
Insert Sarcasm Here
https://acurazine.com/forums/showthr...t=94-97+Accord
v4 and v6 have the same suspensions, they're both 94-97 accord suspensions.
Originally Posted by Cocoa
You can also go with the Urthodox Racing Pullies, which will give you better gains than the AEM ones because it replaces your crank pulley.
For suspension, go with anything that was made for the 94-97 accords.
Intakes come from the 98-02 accord models.
Exhaust- you can buy the muffler of your choice and go with custom piping.
You can buy the Acura CL Type S camshafts and have them machined to fit your car if you want some internal work done.
You can also upgrade to the CLS intake manifold and Throttle Body.
Theres MSD ignition, magnacore plugs, and then there's your spark plugs you can replace with the ones of your choice.
You can fit the Comptech supercharger on our cars as well. Or you can go with nitrous.
my mistake, the 94-97 fits the 2.x most of the time. But there are SOME parts that are interchangeable.
(Mid-Atlantic)
(Mid-Atlantic)
It's all good, we were reffering to the motor. Anything v6 for the cl is the 98-02 accord, but the suspension is 94-97.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
